pressure Plug 0332135
Bobbyd83
I am missing two of these plugs on the cylinder of a 1994 evinrude 150 hp what does these actually do and how do i wire a temp gauge to the block. On the port side there is a tan and there is a white wire coming out of it going into the red plug i believe
jakedaawg
One maybe had the temp sensor, the other may have had a h2o pressure guage hose...hard to say without seeing what and where you are referring to...these are just wild *** guesses...
Maybe post a couple pics for perspective...
Faztbullet
Port side wire for temp alarm and quikstart feature, should be tan on starboard side also. Install a water pressure gauge as instant reading.
Bobbyd83
question about a plug
What does this part do? what if it is not installed does it effect alot, is this where you get the temperature sending reading from? Plug 0332135
GA_Boater
Please don't start multiple threads on the same issue. Thanks.
Bobbyd83
what does this plug do?
GA_Boater
Bobbyd83
How many times will you start a new thread with the same question? 3 times the threads have merged. Do not start another thread on this subject.
Read this thread before posting! Members are trying to help you and you are ignoring their advice by asking again in a new thread.
