Pressure test 1990 Alph1 Gen1
Drivewayboater2
Hello All,
I recently replaced seals on my outdrive. Did both upper and lower. Shift shaft seal, replaced impeller with all new seals and replaced bearing carrier. I replaced everything but the universal joint seal on the top half since it is a bit tricky to get the preload correct. Did a pressure test and found it holds 3lbs of pressure for about a minute. What’s the best way to determine where the leak may be? Spray bottle with soapy water? If it’s in the seal on the upper half beyond the universal joint what’s the best way to determine that it’s leaking? Any help would be appreciated.
Scott06
Hello All,
Spray soapy water or gas leak detector (from hardware store) on the seal areas including shifter etc
Was it leaking oil out the input shaft before the work?
Might double check the quad ring between the two halves and the fill and drain plugs are holding
tpenfield
+1 soapy water. How much do you want to bet a quarter that it is the one seal you didn't replace 🤪
Drivewayboater2
Thanks both!
I figured soapy water was in order..
no sign of leaking before seals were done. I figured with the age and not knowing what had been serviced I figured I’d do them. Boat sat for 2 years before i purchased. As I removed things off the boat I rebuilt everthing… EXCEPT THE SEAL TPENFIELD is referring to… don’t want to take that bet…ugh
any tips on doing that seal? Getting the correct preload can be tricky. I’ve got manual #6 and have read up on it. I’m not afraid of doing the work and the seal came with the kit I purchased. I watched some vids on it but still have reservation. Any tips?
