f_inscreenname
- Aug 23, 2001
- 2,591
After getting my motor put together yesterday I found one of my exhaust manifold was dripping water where it mated to the motor block. Pulled it off and found water in the last (#7) exhaust port. I took the manifold apart and can not find where is was leaking. I put them all back together with new sealant and a home made end cap and let sit overnight. The question is how many PSI should I use to test them? The reason I am even bothering to test them is they are not that old (5 years) and the bay is brackish water (I try to flush after each use) . When you look inside they don't look that bad (I've seen bad ones) and I think it may be the gasket or the exhaust elbow that is older then the manifold.<br /><br />What is half of a admiral? #500 I need to get a different hobby , boats, message boards about boats.
