enginesilo
- Jun 9, 2008
- 355
Is it ideal to only do a pressure test, or should I plan to do a Vacuum test too? I already read the sticky but there wasn't a ton of specifics.
I was planning on building a simple pressure tester, but may opt for a gauge with pressure and vacuum if its ideal to do the vacuum test too. My plan was to build it and then use a bike pump for the pressure end, and use a brake bleeder for the vacuum.
I saw some oil drip out of my weep hole in my Alpha 1 Gen 2 drive last year so I want to do a pressure test while its still winter. I took the drive off and have it ready to test as 1 piece, and I then plan to separate the top and bottom and test them separately.
Any tips on if Pressure and Vacuum should be done appreciated.
