I apparently got it wrong. I resealed my lower unit and it is still leaking. Disappointing at least. Anyhow I have a pressure tester hooked to it while the lu is still attached to the motor and it is underwater. Bubbles are coming from the top hole of the four water intake hole which are on each side. The prop shaft, no bubbles at all. If it were the shift rod seals I think the bubbles would travel straight up. Lower unit has to come off either way. Can it be taken for granted that the leak is in the driveshaft seals under the water pump? Just want to order parts ASAP for when I get to the fix. I realize I can again test the lu once off the motor but would like to have the parts ready for when I can get it all done in one session.By the way the pressure tester is hooked up to the oil vent, not the fill if that matters.
