Pressure treated wood and aluminum boats
Comoxsam
I see this advice getting posted a lot so I thought I would start a thread as a warning to all those thinking of using pressure treated wood in (or around) their aluminum boats and trailers.
Apparently certain types of pressure treated wood contain copper which causes dissimilar metal corrosion with aluminum.
Below are some photos of the bottom of one of my boats. The boat was sitting on pressure treated wooden bunks that were covered with carpet. The carpet got wet and the chemicals leeched thru and corroded the bottom of the boat quite badly. All this damage happened in 1 year!
http://i438.photobucket.com/albums/qq107/ComoxSam/P1030707.jpg
http://i438.photobucket.com/albums/qq107/ComoxSam/P1030705.jpg
http://i438.photobucket.com/albums/qq107/ComoxSam/P1030700.jpg
http://i438.photobucket.com/albums/qq107/ComoxSam/P1030698.jpg
There are some people who have been using pressure treated wood with aluminum and haven't had any problems. I suspect it might have to do with a different type of treatment on the wood. The stuff I used had a tag right on the end saying not to use with aluminum. Unfortunately I didn't read it until it was too late.
I'm not saying never use PT wood on your boat but this is a warning about what could happen.
Hope this helps.
Bob_VT
Re: Pressure treated wood and aluminum boats
Been discussed here hundreds of times.
The new PT wood is ACQ which is treated with a higher concentrate of copper oxides....... which is "supposed" to be safer than the old stuff which contained more arsenic.
The copper oxides are highly reactive.
PT is primarily treated against insects and fungus.
Your damage can be repaired. A few coats of gluvit epoxy on the exterior of the hull will fill in those gaps and since it is under the hull..... it will not have to be painted to prevent UV damage.
Comoxsam
Yep I see it is discussed a lot yet I continue to read posts where someone mentions using PT wood and everyone has to jump in with the warnings. Maybe we need an aluminum boat FAQ around here. :)
I guess I could repair my boat with some epoxy but I'm an aircraft sheet metal guy and glue doesn't seem right for some reason....
Bob_VT
Fighter jets have their skin applied with epoxy. The automobile industry uses epoxy too which will survive a crash.
The gluvit coating is good stuff...... here is a good article you might like http://www.steelheaduniversity.com/gluvit.htm
dozerII
That is pretty nasty, good thing there is lots of info on this site, as it stopped me from using pt plywood for the floor in my Starcraft.
Comoxsam
Yes I feel really dumb for letting this happen. Hopefully others will be more informed.
RickSewall
This info in right on. I took off some pressure treated plywood and it had begun to corrode the aluminum in a few months. Good advice and do not use it.
