Re: pressurized 2 line gas tank problem
Sure. Gas is going through the diaphragm (it shouldn't). There are a few possibilities why. It depends partly on whether it has a plastic button or a metal button. Plastic or metal, the diaphragm could have a hole through it. In addition, the metal ones have several additional possibilities:
1. There is a nut on the bottom end of the push button stem. It could be loose.
2. There are two metal supports at the bottom end. They may be distorted or rusted
3. The bottom end of the push button stem may be corroded.
4. The metal button is supposed to spin freely on the stem. If it is corroded and stuck to the stem, you tend to rotate it while pushing it, which unscrews the nut on the bottom. See #1
In any case, you have to take it apart and fix it. Parts are available.
