dirktoesup
- May 6, 2011
- 7
I would appreciate any feedback on this ignition question. I have a 1989 Force 125hp o.b. which seems to run acceptably, however in reviewing the prestolite wiring diagram I note the following:
1. the diagram indicates that the ignition coils need to be grounded(black wire). the four ground wires coming off the four ignition coils are attached to the mounting plate(bracket) and this is not grounded to the block since it is rubber mount isolated. The two CDI units are grounded to the block(not the bracket) via two black ground wires but are not electrically connected to the mounting plate(bracket) since the bracket is isolated from the CDI units via their own rubber mounts. The two black with yellow stripe wires are connected to the terminal strip and seem to function as they are supposed to. It seems to me that the six black coil ground wires and CDI unit ground wires should be attached together probably to the mounting plate(bracket) as commen ground. If I simply attach a ground strap between the mounting plate(bracket) and the block, I lose spark to #3 and#4 cylinders. I find nothing specific in any manuals or on line to either support or otherwise answer my question. Everything I've seen simply shows all 4 ignition coils and the two CDI units need to be grounded(without being specific as to being grounded to the block or to the mounting plate. Can anyone clarify this for me? Thanks in advance
