Hello,
I have recently purchased a boat with a 4.3 V6 Mercruiser. I had an older boat with the 3.0LX and I knew my way around that motor pretty well (replace starter, slave solenoid, etc.). The 4.3 V6 is brand new to me.
Engine has approximately 100 hours on it, and it is a 2006. The guy who has been servicing the boat said "the boat hasn't been used much, so I've only really been doing oil changes on it".
I don't want to find out a few years down the road that there were "recommended" items I should have changed that would make it last longer, or that there are common faults I should have just fixed in the first place. For example, my Mercruiser had a flaky starter when I got it (it was the old really heavy kind) and I bought the new style for only $60 and replaced it. WAY better starter. Also would have replaced the slave solenoid and alternator belt "in hindsight" if I knew then what know now.
So here's my list for the 4.3 V6... what am I missing?
-Replace drive lube
-Engine oil change (last time it was done was spring of last year.. it has been a whole year)
-Spark plugs, cap, rotor.. should I just leave these for now? They only have 100 hrs on them.....
-Exhaust flapper... do these fail like the Mercruiser ones? Should I check mine and/or replace it now?
-Fuel filter.. is there one? Boat is TKS/carburated (not MPI fuel injected)
-Run some kind of fuel cleaner (I use Techron in all my cars) to keep the carb clean?
-Look at belt.. I believe it's a serpentine belt.. check for cracks and replace if necessary so I'm not stranded (more likely due to age cracks than usage, I suspect)
-Battery -- will have to look at this but if it's original to the boat from 2006, I'll replace it right away! If not, I'll use the boat for the rest of this summer and then buy a fresh one for next year.
Any other thoughts? Common problem areas I don't know about like the 3.0 slave solenoid, 3.0 starters, etc, etc.?
I'd like to run the boat for the next 3-4 years with only oil and drive lube changes (and a quick look over the engine/fluid level check every spring). I would rather replace parts now than try to do it piece by piece .. I have access to a garage and tools now, but the boat will be out of town and/or in the water from now on, so it's MUCH easier to get a part and swap it now than later on.
Thanks!
-Replace drive lube
Thanks!
