Previous Rub Rail and De-cap Hole Repair
90kacoupe
Hey everybody,
I am in the middle of a wetsand and buffing my 1987 Supra Sunsport. I started this project by removing the Rub Rail so I could either reseal or replace the rub rail. I was aware the previous owner had the boat decapped for wood repair. After removing the rub rail, it looks like this boat has either been de-capped many times, or the rub rail replaced many time. There as a bunch of holes around the lip. I mean probably 100+ extra holes. It looks like swiss cheese in some spots. I am planning on trying to repair this to some extent.
Does anybody have any good methods of doing this?
I my current idea is to drill them out with a 1/4" drill bit. Then, use Fluted 1/4"x 1.5"L wood dowels coated in epoxy to fill the holes through the cap and hull.
This way when I put new rub rail on it, I do not have to worry about where the screws line up. There should be something substantial to screw into.
What do y'all think? This is the only way I know how to easily fill the holes in both the cap and hull.
I can post pictures later this week.
sphelps
Just thinking You could fill the holes with 5200 then drill new mounting holes in the rub rail ...
Pics will help ...
90kacoupe
I'll get some more pictures. I'm worried with just straight epoxy about getting it through the holes in the hull. There is a gap small gap between the hull and the cap. I know I could inject it into the cap's holes, but I'm not sure how to get it into the hull's holes.
stuff marine tex in the extra holes. you are over-thinking it
