Primary Restoration Tools??
Holymann
What tools are the mainstay for restoring boats?
Mainly talking about electric tools.
Holymann
crunch
Re: Primary Restoration Tools??
1- 4' grinder.
1- circular saw.
Another 4" grinder (for when the first chokes on the dust)
A shop vac. ( I use the wifes (don't tell her) home vac as it has suction plus, and throw away bags)
I use a pressure washer to blow all the dust and oil, etc. off and out the drain.
Other than that, it's hand tools ( a power screw gun is optional)
What you really need to do is get a good quality dust mask... I'm talking the rubber over your face with filters, not the cheap "surgical mask".... If you can taste it, you are breathing it.
i386
In my "demolition" phase I have found the following tools very useful...
Hammer
Chisel
Punches
Prybar
Wire brush
Electric Drill
Wire Wheel
Rotozip (grinder and sanding discs)
Dremel
Shop Vac
Besides all the fiberglass related tools I think I'll need a random orbital sander at some point. A table saw would be nice but I think I can make due with my skilsaw.
xtraham
+ a chainsaw if you get POed
Mark42
Add a 7" polisher.
And a set of electic crimp connecters and crimping tool.
andy6374
To add to the already started list...
Essentials:
-die grinder with assorted carbide bits
-Crap loads of assorted clamps
-tyvek suit
-Heating lamps for curing resin in the cold or a nice space heater.
Stuff I also use alot but not necessary for all projects:
-Router
-Jigsaw
-bevel
-compass
-bandsaw
dmarkvid2
Don't forget safety glasses when all the fiberglass and wood chips are flying around. A set of hole saws. I think you'll know what you'll need as you go along. Christmas is only about 10 weeks away, good time to ask Santa for power tools
danpemby
How cold is too cold? I am trying to wait until I can not fish any more before I start?
Sorry Holyman not trying to hijack the tread but it sounds like we are in the same situation (about to start soon) and our tempertures are the same.
Holymann
Okay,
Let see if I can sum up all that has been rendered to the primary tools.
Non Electric/Pnuematic
Hammer
Chisel set
Hole punches
Prybars
Wire Brush set
Bevel
Compass
Planer
Box cutter//Razor knife
Assorted Clamps
Electrical tool set (Strippers/crimpers and assorted parts)
Tyvek suit(s)
Industrial Dust mask
latex gloves & foot wraps
ELECTRIC
4.5 " angle grinder
Circular Saw
Power Drill (w/screw attachments)
Router (w/rounding bits)
Jigsaw
Orbital polisher
Heavy duty shop Vacumm
Power Washer
Does this cover the basic tools???? 8)
I do have most of this, thank GOD....
Holymann
If I could have Only 1 Electric Tool,...........
It would be 1 of my several 4,1/2" Grinders,...........
With an assortment of Discs.............
Bob_VT
What!!! No one said beverages!!! A decent digital camera and a VERY understanding significant other!
Access to a computer helps too!
