Primer bulb hardness
starkyb
I have a general question about my primer bulb. When I am about to start my 75 horse Mariner for the first time of the day, how hard should I squeeze the primer bulb. I was told by someone that I shouldn't get it as hard as I can but firm enough to get fuel in the carbs. Does anybody out there have an opinion on this?
gm280
I do remember many years ago that primer bulbs would get solid feeling when squeezed and the fuel was pushed towards the engine. However, I had heard that the EPA put a stop to those type primer bulbs and made the market change to these newer designs that just get a little firm feeling when priming. So don't expect the bulb to get solid or stop being able to squeeze when priming. It never will...
The primer bulb is a manual fuel pump.------------It saves excessive cranking with the starter to fill the carburetors-------The primer bulb must go hard after the carburetors are filled.------If it does not then there is a leak in the carburetor / fuel pump / hose connections.------The bulb does not need to be hard once the motor is running !!!
Mi duckdown
primer bulb is only needed to fill the carb/ carbs.. Once started, you should never have to pump the bulb again.??
Texasmark
Don't know what you are talking about. I recently bought a Quicksilver Mercury, OEM primer bulb and hose and the bulb was just like it's been for 50 years. Has a check valve such that once you prime the engine and it gets firm/hard it holds the fuel till the engine uses it. What changed is the manner the engine is choked. An "enrichment valve" is now used (was on my 2 stroke, '02) rather than a manual butterfly across the venturi for choking.
