I have twin 1998 90hp engines model # E90SLECM on<br />a Glacier Bay Cat. Each engine has seperate 50 gal. fuel tank. The primer bulbs on each engine will not pump up (60% of the time). Replacing the bulbs had no effect. It is a problem with engines cold and warm. When engines are shut down at sea for more than 10 min. Engine or engines won't start accompanied by flat primer ball.Once I can get some fuel into line (I have resorted to siphoning) the engine will start.This problem is<br />intermittent and a real pain. Gas has a terrible after taste.<br />Thanks<br />JD
