I have a 1985 40 hp Johnson that keeps sucking the primer bulb flat and I cannot figure out why! It will run fine for 5 minutes or so then the primer bulb goes flat and bogs the engine down. The time varies on when this will occur. <br />When I first purchased a good fuel line and got away from the walmart junk the motor did fine, but started doing it again the 3rd time out after switching lines. The motor runs great when it is getting fuel.<br />What I have tried.<br />-replaced the fuel line and bulb with a good line from an OMC marina.<br />-tried 4 different gas tanks (metal and plastic)<br />-went away from the quick connects and just put a barbed nipple on the gas tank.<br />-inspected all the filters/screens in the fuel tank.<br /><br />I would think that the motor is doing its job since it is sucking the bulb flat and it has to be in the fuel line before the primer bulb?<br /><br />I am at a loss, Any suggestions would be greatly appreciated!<br /><br />Thanks,<br />Jason
