primer bulb went flat
junior1113
noticed rpms were at 4500 and had my buddie pump bulb and it went flat on him after a few minutes wot rpms went up to 5800 where it should be. thinking flat primer is related to low rpms and rough idle when cold started. what would cause primer to go flat was thinking new primer and new siphoner on gas tank.
petryshyn
Re: primer bulb went flat
Think of your primer ball as a poor mans vacuum gauge. If it goes flat, its telling you there is a restriction between the tank and the fuel pump:
-vent may be plugged (try running with filler cap loosened)
-inline filter/water trap plugging up (if so equipted)
-line from primer to tank kinked or collapsed
-bad anti-syphon valve at tank (if so equipted)
-restricted tank screen (if so equipted)
noelm
it is a restriction between the bulb and the tank!
w2much
Just had the same issue with my 1996 150 HP Evinrude. Changed the fuel water seperater and the anti syphon valve and it was good to go. The issue is not the engine but the boat although my engine alarm kept going off(fuel restriction/ temp alarm).Great feature on this engine.
tashasdaddy
the reason the rpms pickup up, is the motor was running lean, low fuel/oil to air mixture, good way to ruin a engine.
junior1113
ok water seperator is 2 days old and i tryied bypassing it with same results. i have no alarm. so next step is siphon valve on tank?
countvlad
thats what i would do.. sounds like the ball might be sticking
