Re: Primer celenoid on 1987 Johnson 200
I have had a starting problem with my engine (early 80s 175, discussed in another thread). What I finally came up with might be worth trying for you:<br /><br />Really pump the bulb. Not just firm, but as hard as you can get it. I've been around outboards all my life and have always just pumped the bulb until it firmed up. This engine I really need to pump it more than that.<br /><br />Use the key primer (key in on position, key pushed in) for at least 8 seconds. My engine actually starts significantly better if I hold it in for a long, 8-10 seconds - and that's 8-10 seconds, not a quick count 1 - 10. That's a long time when you're sitting there starting a motor, and the tendancy is to count fast and make it more like 3 to 5 seconds.<br /><br />Doing these two things (really pumping up the bulb and priming for a good long time) made all the difference in the world for my engine. It went from a very frustrating cold starter to a easy, quick starter- first or second try every time with hardly any need to coax it along as it warms up.
