I have a 78 235 johnson and have had carb problems. I have a set of like new 83 235 carbs. They have the primer choke and no choke plates. Can I retrofit to the newer primer choke system? The fuel rail that supplies fuel to the carbs has a small line that is plugged. Can I use this to feed the primer solenoid? and if so what else do I need to retrofit Thanks In advance
