Primer Options, which is better?
L2attler
I will be using a self etching primer on the bare aluminum.
Then I was going to use one of the following. ( Price does not reflect on my choice, as it is not a signifficant difference )
Rust-Oleum Clean Metal Primer
http://www.amazon.com/Rust-Oleum-7780502-Stops-Quart-Primer/dp/B001005RH0
P
etit Protect Above and Below Epoxy Primer
http://www.iboats.com/Pettit-Protect-Above-Below-Water-Epoxy-Primer/dm/*******.393193454--**********.721560851--view_id.22271
U
raglow Epoxy Primer
http://www.iboats.com/Uraglow-trade-Epoxy-Primer/dm/*******.393193454--**********.721560851--view_id.363482
W
hich would you choose?
Woodonglass
Re: Primer Options, which is better?
Why don't you keep your posts all in one thread? It makes it much easier for everyone to follow your project. What paint will you be using for your Final Coat?
L2attler
Petit easypoxy single component polyurethane.
Sorry, I should start doing that.
Woodonglass
I'd use Pettit's product to ensure compatibility
