Re: Primer problem
I know you are trying to rope start the motor, but does this engine have electric start as well? If it does, look for a red lever on the primer solenoid. If that lever is set in the MANUAL mode, that's the reason the bulb will not firm up. You are merely pumping fuel directly into the engine. The primer solenoid is the "choke" for the engine. When you push in on the key when starting the engine, the solenoid injects fuel into the engine. However, if you ran the battery down and had to rope start the motor, you can't prime it so you turn the lever to MANUAL, squeeze the bulb a couple times, then set it back and use the rope to start it. Simply wrap the rope around the flywheel and pull. Make sure nobody is behind you so you don't hit them in the face with the end of the rope.
