primer solenoid ohm test??
spanishmak
hi
my primer solenoid on A 200 HP 1979 johnson works manually,but when i point the lever in automatic position And push the key in it does not click or let gas out through the hoses.there current going to the solenoid when i push the key in(checked it with tester).What i want to know is is rhere a way to test these with a tester to check it electrically or do they only break mechanically
also went to rebuild this solenoid but could not get the needle out could this be why it doesnt click.
