Hey fellow boaters! Bough a beautiful ~35 years old Princess 286, one year ago, it has otherwise excellent looking hull but one of its spray rails or running strakes has a small hole in the mid of the boat that got widened to 1x3cm hole after blasting crushed glass. From this hole, I drilled some more holes to lower / aft side of the spray rail and got 100-200ml clear, odorless water out.
This spray rail is square formed, surrounded by a 10mm fiberglass, it is hollow but filled with urethane, goes from bow to aft. We got freezing weather here, so during winterization gravity pulls water to aft through the square spray channel and I suspect ice has made tiny cracks to the inside of engine bay from which water, last summer as well, was seeping very slowly inside to engine bay, but only up to 1-2 liters as after that the pressure / level was in equilibrium with outside water level.
Comments appreciated on how to treat this?
Before I fix the 1x3cm and my drilled holes, should I
Video showing the crack, spray rail and water coming out from freshly drilled holes:
VIdeo showing how water seeps in from spray rail up to engine bay:
Many thanks for any comments!
PS. Will be doing some exciting microcontroller + industrial 1000nit 7" touch console based diesel engine upgrade to this boat, off goes the 30+ year old Volvo Penta electronics, will post news of this to this excellent forum later!
- let it dry like this for couple weeks
- run strong wire from aft to hole removing urethane and create an air channel, then use midly hot air fan to blow through spray rail for a couple of days
- open it more aggressively with grinder first?
