Pro liner in an aluminum Jon boat?
warbuzzard
Does anyone know or has anyone sprayed the Spray on bed liner in an aluminum boat? Does it really reduce noise?
Bob_VT
Re: Pro liner in an aluminum Jon boat?
not me but I have heard yes it quiets things..... it also creates future repair nightmares...... :(
5150abf
And it is super heavy, as pointed out once you put that on it won't ever come off so if you damage the boat and need to repair it you are sorta screwed.
Have a buddy with spray in bed liner that took a spill in flip flops and messed his back up.
CheapboatKev
Whats wrong with noise?
I sprayed bedliner in the lil cubby areas of my boat, since fishing pliers and what not will be stored there..But I wouldn't spray my entire boat inner hull with the stuff..What type of boat is this? I assume (gasp) it's a little john type w/tiller?
AZMinyard
I used the spray can version from Walmart on the bottom of my boat. Can't really say there was any noise reduction, but it is non-slip and can be stripped off later. Much cheaper than the pro-shops too.
