Pro Torque starter bolts from Mercruiser
Bt Doctur
Customer bought the new Pro Torque starter but it didnt come with bolts, went to same dealer and asked for starter bolts for a ProTorque .Recieved Quicksilver 10-805343 2 .
A tiny bit too long.Had to add a drive mounting washer to eack bolt to actually get the bolts tight otherwise loose bolts break or break the engine casting
Ayuh,... I ground 'bout that much off 2 starter bolts the other day, which works too,....
alldodge
Been many discussions here lately of starter bolts. I measured the PMG starter and its 3 3/16 wide. ARP and Dorman sell 3 5/8 long starter bolts
Do you know how long the ones you got where?
Looking up 10-805343 it shows 6 inch long and NLA at BAM
https://www.mercruiserparts.com/8053431-screw
Ayuh,.... I didn't measure the ones I did,.... maybe today I'll pull one out for the purpose,.....
I took off a tired big motor, staggered pattern starter, 'n put a p/m starter back on,....
While grindin' the ends off the bolts moves the knurling up, it's still well within where it's gotta be,....
