Evinrude Boater
- Jul 6, 2004
- 1,144
After removing the engine I wanted to reinstall the Alpha outdrive for storage but it seems to be more difficult than installing with the engine. I can't even get the bolts past the holes to get a nut on them. I took off the big rubber ring since it was getting pinched but it's no better. The shifter shoe is just about to contact the shift rod so I'm wondering if it moved a bit. All I did was remove the outdrive and lay it down while the engine was lifted out then picked it up again to install it back on the boat.
Does the prop lock into gear when it's fully installed because right now I can spin the prop and I hear a clicking and the driveshaft doesn't spin.
