les morgan
- May 11, 2007
- 49
1985 Merc 50hp. Water pump quit pumping while running.(see Lower Post)
I found the impeller seperated from inner brass sleeve. Replaced impeller
and gasket. Replaced lower unit, motor seems to start fine but no water
from pee hole. Removed lower unit and shot compressed air back thru
pee hole hose could not find any blockage. Double checked impeller and
could find no problem. Installed water muffs and turned on water while I
had the lower unit off and the pump seems to be getting water. Reinstalled
lower unit-started engine-still no water flow. Any help would be greatly
appreciated......
appreciated......
