problem starting 1990 mercruiser 4.3L
ahunter4063
I just replaced starter and relay soleinoid. When I turn the key all i here is a clicking sound. Also the battery is fully charged. Any help or ideas greatly appreciated!
tpenfield
Re: problem starting 1990 mercruiser 4.3L
My idea would be to check to see that you connected things back up properly. If you have a multi-meter, you can also check for voltage at the solenoid and starter.
Ayuh,... Welcome Aboard,... Odds are, there was nothin' wrong with the parts you already replaced,...
Remove, 'n clean to shiny metal, All the wiring ends in the startin' circuit...
Includin' the Grounds, 'n Both ends of each wire...
