I have a problem with a motor that has me in a quandry...I started it up this morn on a hose and it started right up as it always has. Been 2 months since I last ran it. The problem is that it is idling at 1800-2200 rpms on the tack...way too fast. It will run for a second (at 2200)then miss (down to 1800) then back up. Starboard plugs are oily and clean. Other 2 are sooty with oil...normal. Using timing light found no fault with spark. I mix gas/oil in fuel tank...2 mos old, using OMC oil. I've never had a problem with this motor before and this has me stumped...tiv for whatever you can do to help.
