problem with 1973 20 hp johnson
ctrevis7
i have a 1973 20hp johnson and sometimes when i go to open it up to full throttle it seems like it is slipping and gets loud but doest go any faster but other times it is fine. what might be the problem?
Thanks in advance
Tyler
F_R
Re: problem with 1973 20 hp johnson
Probably cavitating. Possible slipping propeller hub, but probably not, because once they slip they usually don't "heal".
Do you have weeds in your water that could be getting snagged on the lower unit? That will make it cavitate.
ctrevis7
No i dont think there are any weeds im running it in a open lake i was told it cold be the carb? but not really sure it feels like the gears are slipping but my lower unit lub it good with no water
F_R
Don't listen to the guy that told you it is the carburetor.
I was trying to save myself some typing, but you might as well go ahead and check the prop hub. Here's how: Make a mark on the plastic prop nut and another on the propeller, aligned with the first one. Run the motor till the suspected slippage occurs, then stop the motor and check your marks. If they are no longer aligned, the hub slipped. But if they are still aligned, repeat the test, because there is a slim chance it stopped slipping in the same position.
The prop hub is the only thing that can slip, assuming it is a "slippage" and not making a lot of grinding noises, etc. Otherwise, it has to be cavitation. Grinding, jumping, and other assorted nasty sounds would be serious internal damage in the lower unit. You don't want that.
ctrevis7
oh ok thanks so much! i took it out this morning with my dad and hes a big guy around 300lb guy and it slipped a good bit but i dropped him off and ran it with just me and it ran ok. could it be the load weight? and i will try the test here in a few minutes. thanks so much
How much would it cost to repair the hub?
