hello everybody
I wonder if anyone has had a similar problem.I swapped from a 305 to a brand new 350 old style(with the 12 bolts at the intake manifold),i bought a used flywheel because the old one was smaller and a new coupler.When placing the engine onboard and trying to align it i find out that when i turn the cranksaft the alignment goes away.To make it more clear at one position of the coupler the outdrive's shaft engages very smoothly to the coupler but when the coupler turns i have to push with some force to get the shaft into the coupler.I thought that the problem would be the used flywheel but when taking out and examining better at a machinery shop i find out that the coupler's bore is badly fitted into the rubber making thus the saft turning conically.I measure the deviation at the distance of the gimbal bearing is about 0.2 inches which in my opinion is excessive and will damage either the coupler itself or the gimbal bearing.I paid 220 euros for that new coupler and i'm afraid the dealer won't recognise the problem.Has anyone expirienced such a problem?
