J-problems
- Jul 2, 2014
- 6
So the problem here is cant get the engine to turn over. Got a brand new optima battery, fully charged inside it. new spark plugs, new wires, new blaster coil, and all the wires and everything are connected all the way around. every fuse has been gone over and still you turn the key and it will not even turn over or make a sound. so what stumps me is the lights are on, the dash has power, the leg even goes up and down, bilge pump works fine, same with the fan. check the throttle it works, it gets gas, and still wont turn over. the only time that it has shown any sign was when someone accidentally touched the wrench an jumped the power straight to the starter and it turned right over. so is there anyone out there that can put any insight to this problem.
