I recently purchased a 1983 Johnson 25Hp outboard. The fellow i bought it from said it hadn't been ran in about a year to year and half. The first time i tried to run the motor it started on the second pull and idled nicely. I trolled around with it at low speed for around 20 minutes before i took the motor for a run. It seemed to run very well until i went to back it off to a trolling speed again. When I did this, it died out on me and would only start when I had the choke pulled almost the whole way out. I have tried the motor a few times to start it while the boat is still on the trailer and motor is in the water. It will only start when I have the choke pulled most of the way out and i can not push the choke back in at all even after the motor is running. I can't turn the throttle back to less then half way or the motor just dies. Do I have a dirty carb that i can just fix with some carb cleaner? Anyone have any suggestions on what it might be wrong? Thanks for your help
