searay ted
- Feb 23, 2009
- 6
i have a 1995 Searay with a Mercruiser 4.3 litre motor and a Alpha 2nd generation outdrive. The first start of the day is allways the same, The motor will start and run for 5 seconds then quit. To get it started I have to raise the engine cover, unscrew the gas filter, then start the engine and screw the filter tight, and then it will start every time for the rest of the day without unscewing the filter! I have checked the antisiphon valve and it works fine, the fuel vent is clear as I blew through it with compressed air, could it be the fuel pump, even though it works fine all day with numerous starts. I was told by the mechanic at the boat shop that the only thing he could think of was that the needle and seat could be sticking and not letting the fuel in . I also use seafoam about every 4th tank of gas. I would appreciate any help.
