AMMO DAWG
- Aug 3, 2012
- 227
Hi all, was hoping those out there with some experience with the Mercruiser 3.0 can provide some insight, not sure if I’m getting some bad gouge from the local machine shop or there is something there.
Some background information, have a 2006 Sea ray 185 with a Mercruiser 3.0 that was I bad shape, had hydro locked, lots of corrosion, bad head gasket etc. I took it to a local machine shop and he tore into it while I was on travel and replaced everything to include stainless without checking with me. If I knew it was that bad, I would just have replaced the engine I believe. Regardless, took it out for the first time and took it easy, ran okay for the first 40 minutes or so, thought the power was a little lacking, then the oil pressure fell to zero and I heard some knocking. I shut it down immediately and let it sit for a while. I was out in the bay so I thought I would see if it would start so I could limp to the ramp. It was sluggish/dragging starting, but started and pressure was back up, however there was a discernable knocking sound if I increased the RPM’s. I limped it back to the ramp and last weekend pulled the engine (again!)
I took it back to the machine shop and he insisted that he didn’t understand what it could be. He called me today and claimed the square gasket had blown out and that there was water in cylinder number 2 and the head gasket was fine. He provided that the outdrive had gotten clogged and caused the water to get in the cylinder because he could see a burnt spot on the exhaust manifold. Does as a note the manifold/riser, water pump and outdrive impeller are all-new, first time on the water.
I have a bit of experience with engines albeit autos and this simply doesn’t track with me. The frustration is regardless what he does I don’t feel comfortable taking this engine out again. Like to hear your opinions/experiences and thanks in advance.
