I have a new mercury 9.9hp outboard. I broke in the engine for a little over an hour just like the manual stated, using a 25:1 gas/oil ratio for the first tank and it ran fine. The second time I brought it out, still using the same tank of gas I began having problems. I started it up to leave a fishing hole and began cruising for the boat ramp; about half way across the lake it bogged down and died. I started it and went to take off and it bogged down again. I could start it and it would idle fine, and would run fine at a low rate of speed but if I tried to give it gas and plane the boat out, it would bog down and die. As I said, this is a new motor.......what the heck is wrong, do you think I somehow fouled out the plugs, and if so how did I do it.
