I have a 2002 200hp Mercury Carbed Saltwater motor, that is not peeing out tell-tail. I just replaced the impeller and housing so it should be fine. Water is sputtering out of the idle exhaust vent below the tell tail. The motor is not over heating. I am running it in a 100 gallon tub with water about 5" above the lower unit. I pulled the thermostats and tested them, the work fine. I pulled the hose to tell tail and it was clear, even poured water into hose from thermostat and it came out tell-tail. The motor was idled up to 1100rpm with no overheating for about 4 or 5 minutes. My thought was the poppet valve is stuck open, I ordered a rebuild kit and will check it and install the new kit when I get it. Anything else that I should check or worry about? Do not have a water pressure gauge, bought one and am working on installing it after I get the right barb coupler to mate the two different sized hoses.
Serial number is OT566776
