Old Boat Luvr
- May 15, 2012
- 34
I have a 1970 Starcraft Holiday I'm trying to get up and running and finally got the motor put back together and running right and I changed the lower oil and installed a new water pump impeller assy. Then I started it up and found out it won't go into gear. Not forward or reverse! When I reinstalled the lowere case after the WP replacement did I screw something up? or is the outdrive toast? Any suggestions as to what to check?
