Valley Boater
- Oct 1, 2009
- 80
I got out my fairly "new to me" 1984 Johnson 8 hp over the weekend for a tank test before fishing season. Since I got this motor 2 years ago the starter pull rope was usually limp by an inch of so when not running. I tried to start the motor yesterday and found that the rope didn't retract into the motor until I reduced the twist grip throttle from "start" to "slow" or "stop" and even then it rewound very sluggishly. It looks like the previous owner had reduced the length of the pull rope as the spool looks to be only half full.
I believe the spool should have 56 1/4" of rope and I have about 36" when the rope if fully extended. There was a lot of grease on the rewind assembly which might have been the previous owner's attempt to get the rewind smoother.
My thought is I need to replace the rope with the proper length and at the same repair time carefully release all the tension on the spool spring and re-tension at 16 1/2 turns (CCW - thanks Lee Roy) before re-spooling. Does this sound like the best first option? I'm confused why the throttle would bind the rewind process.
Thanks for all suggestions.
Don
Don
