Problem with Snowblower
zach103
Ok so i've taken everything apart and i think i have found the source of the problem... the gas is flowing into the bowl so thats fine.. and i cleaned the main jet.. but when i push the primer no gas wants to come into the intake lke it should.. .. what should i do
rbh
Re: Problem with Snowblower
What kinda primer clear/black rubber push half ball style or primer pump?
waterinthefuel
First, is the fuel valve on? (if it has one) I would say it's a bad primer if the fuel line isn't clogged.
Lone Duck
Master Chief Petty Officer
Is it Tecumseh or a briggs ? Is the primer on the carb or in line ?
gstanton
Had a similar problem with mine last fall. The half ball push primer bulb had torn at the base and would not push fuel through. On my Troy Bilt, the bulb is mounted on a plastic base that pops off with a blade or screwdriver. As it comes off there is a small tube that is connected. That is what carries the "pressed" fuel to the carb. Disconnect that tube and you're ready to start looking for a replacement. Mine was ~ 9.00 after going to half dozen repair shops. They will want to know what make and size of engine.
zach103
its a push one and from there a small tube goes to the top of the intake
lowkee
99.9999999999999% of primer bulb issues stem from a bad seal or tear in the bulb itself (a $2 part). The other .00000000000001% of the time it is a bad hose or flared hose connection (leaking air) going from the primer bulb. I've never seen it be anything having to do with the carb, just so you can rule something out.
zach103
ok ill just get a new bulb and see if that helps any..
zach103
so i brought the whole carb to the store with the primer.. everything was fine.. he asked where was the nut to hold the bulb on.. at home.. told me too look at it.. theres a tiny hole in the middle of it where the gas flows thru.. i get home and tried clearing it out with some wire.. nope.. got a pin and walaah its running.. .. got 20 bucks and a container of brownies.. i spent 4.66 on a fuel line and filter.
