personally i disagree with Mark, i always disconnect my cable at the motor, then drop the lower unit, after motor is completely back together, i reconnect the cables with the motor and control, in neutral and idle position. turning the shift rod, or moving the shift lever on the motor, can throw shift out of sequence
i am not going to get into a long discussion, back and forth on this. this is my opinion.
