Re: Problems installing new Alpha One
I unhooked the shift cable at the engine and tried to adjust to compensate for th lower being off. All it did was mess up my shift box. I could get it to go into full neutr in the neutral position, but, it would never go into forward. It was still in neutral in the forward position at the shift box, and it would not shift into reverse without much difficulty. I took an Apha One SS drive off and downgraded to an Alpha One, because an Alpha 2 won't mount to my Gimbal and transom setup. Never had a problem when I would remove the old lower. It slid right into place like it should. I removed the intermediate shift shaft from the upper and dropped it int oplace on the lower, with it in the forward position, and it was cocked to the 1 o'clock position. All information I have says that in forward it should be at the 12 o'clock position. I considered removing the upper and trying to reposition the cam on the shift cable to allow it to shift correctly, but got pissed. If I have to change out the lower in the future, I will have to reposition it to the correct angle, where it should be to begin with! Maybe I'm wrong, but I've had every one and their brother over here checking it out and we have all come to the same conclusion. The lower is a tooth off from the factory. Sorry if my post is a little confusing, but I just got back from the lake. I was on my buddys boat! So the beer flowed freely! I appreciate everyones input. As I am fairly new to the boating scene. I sold my hot rod car because I bought a boat and couldn't afford 2 toys! I am not a complete idiot, I am a mechanic, and the basic principles are the same whether it be a car, boat or airplane. I can't hardly stand to pay any one to fix anything that I know I can fix myself. So I get on here,or wherever it may be to get everyones input on my problems. You can never get enough information! Thank you all.
