Problems untightening outdrive lower unit's plug
aJohn79
I have a 2.3L OMC Cobra from 1990. I want to change the lower unit's oil but I can't untight the plug. I bought a screw driver with the widest flat head I found but nothing. The screw driver slips from the slot. I don't want to damage the slot too much. Are there any tips to untighten a plug?
I bought it used last year so I haven't changed the lower unit's oil yet. It's the only service item remaining on my list.
Thanks!
Haut Medoc
Re: Problems untightening transom plug
You need to buy an impact driver & a mallet......;)
aJohn79
Re: Problems untightening outdrive lower unit's plug
uhmm, is there any other way? I don't want to buy an impact driver just for that. Maybe I'll look to see if I can borrow one.
capthook
It should have been one of the first things on your list. But better let then never. I had this same issue with my upper plug. Actually it is called a oil vent screw, and the lower is called the "drain plug". All I did was took a "small hammer" and lightley tapped it a few times then put a lot of grunt into it. It came out. I used a really big flat head as well. Make sure that you replace the seals or you will get water in.
DukesFin
Unless the slot is already damaged, the correct size screwdriver (and a decent quality one at that) will do it...
Lots of pressure onto the head of the screw, slow forceful turning...
If that doesn't work, put the blade of a smaller screwdriver on the top of the slot and LIGHTLY tap with a hammer... LIGHTLY TAP to get it loosened.
aJohn79
Thanks! wow! the impact driver is very cheap at Harbor Freight. For that price I can buy one. Now, it looks like the flat tips are fairly small. Will these work or I need to get something else?
BTW, I already tried tapping the screwdriver but did not help.
marunr
I had the same problem a few years ago on my 2.3. I used a large screwdriver and clamped a pair of vice grips on the blade, down close to the screw head. Push hard on the screwdriver and turn with the vice grips...it works. (Of course the impact wrench would be better!)
After you get it out, replace it with one of the newer ones that use an allen wrench. They're much easier.
