picked up a 9.5 today, rough condition but ran well when he demo'd it, so I sprung for it.
numbers are
9022c
e03817
I couldn't find a working link to a motor guide, any idea what year it is? If it's even a 9.5
Next on to my problem, motor has an old metal gas tank in good condition, new primer bulb and lines, all the fuel lines under the hood look good, motor starts and idles for 3-5 minutes, revs up, and generally runs well, then will suddenly die. The fuel pump looks shiny enough that it might have been replaced, it runs OK when it's running, smokes a little too much I think, and will restart after a minute or two when it shuts off.
it's spraying pretty hot water out the blow hole along with exhaust, seems to be pumping OK.
My first thought is to re-set the carb and adjust from there, it looks pretty clean no telling if the carb needs a rebuild though, the choke is opening and closing fine and if I pull out the choke it'll kill hte motor running, if that helps.
I'm out to do a compression check while I fish for advice
numbers are
9022c
e03817
