outlawfox13
- May 11, 2009
- 96
Ok, well I picked up this motor for $250, and the PO hadnt run it so had no idea how it ran. I did a compression test and got 135 on top and 133 on bottom so I was pleased and bought it. I replace the impeller and rebuilt the carbs, new plugs and gapped to .030 also replaced thermostat and changed lower unit fluid. I was gonna pull the flywheel, but the ignition coils and wires looked new so I havent pulled it yet, got it running great in a bucket, then took it out today for its initial run. It idled great, and started to pick up power well, then all of a sudden the motor jolted before I got up on plane and knocked the motor out of gear. so I put it back in gear and held it down as I throttled up, then it jolted again and I could feel the motor pick up just a hair then slow down a lil and maintain, then about ten seconds go by and it does the same. so for the whole test ride it does this about every ten seconds or so. I am thinking that the points may be off so I will check later, does any one know what this could be? It is a pretty heavy jolt like I hit somthing, oh and what needs to be adjusted or repaced to keep the gear selector down, Im thinking somthing is worn down for it to pop out of gear when the motor jolted.
Thanks in advance Mike
