hi guys not sure where to start just bought the boat got it started finally and it came with two controllers the one on the boat is from the original motor wich is another one. we have the controller that is "supposed" to go to the 115 not sure though, had to work the throttle with the cowl off and can't figure out why it wont go into reverse not sure where to go from here the prop spins forward when we start the motor. do we have to have the throttle cable hooked up to make it go into reverse or how does that work? thanks for all the help and you're time!!!!!!
