Procharged 7.4 mpi question
Chased1
Hello again guys, im having an issue with my 7.4 mpi. Ive only had the boat for a few months and it runs very rich a idle and very lean at wot. I ve played with fuel pressure enough to get it to richen up at wot but of corse that doesnt help the idle mixture being so rich i get fuel and soot out the exhaust. I thought perhaps the injectors were clogged so it took the out and individually cleaned them up good but that hasnt helped. Im now wondering if the map sensor ( still in the manifold) should be relocated somewhere where boost isnt present like in the intake pipe. Vin L354355. Enging has been rebuild with high compression forged pistons.
Ayuh,..... Welcome Aboard,.... Was the 'puter reprogrammed to match the modifications to the motor,..??
Chased1
Im not sure to be honest like i said i ve only had it a few months and its always run like that. The plugs keep fowling and i have to be real carrful at wot because the egt s sky rocket and the motor actually knocks and then retards because of it unless i crank up the fuel pressure
alldodge
Someone put a procharger on it without having the ECM remapped, or it was remapped but was done incorrectly, in any case your looking at trouble.
Remove the ECM and see if it has a sticker from Arizona or Whipple on it.
What did you do to the fuel pressure?
Edit: high compression with a procharger??
it sounds like you are running out of fuel and possibly the ECM wasnt programmed for the whipple charger or the injectors are stock.
something is not right
I also agree, generally the compression is dropped for a blower.
Chased1
Sry didnt meen high compression but higher than stock compression. The builder installed 454 mag forged pistons in it. Can the ecm be remapped without dyno testing ? I live around ottawa canada and there arent any marine dynos around.
alldodge
Blower needs lower then stock compression
Dyno measures power you need to measure Air Flow Ratio (AFR) using O2 sensors.
Your ECM can be remapped using MEFI Burn software with )2 sensors and a AFR meter, or can contact Whipple and have them reflash for your build if it can be done.
Chased1
Thanks for the replies gentlemen ill contact procharger and see what they have for my application
