Project Boat- engine question
I have purchased a 1984 Commodore 277. The boat came with a pair of 488 mercruisers, one of which is locked up. After some tinkering I have gotten the starboard engine running and have purchased a complete 470 from a wrecked Sea-Ray. my question is this: I have the engine mounted on a stand and I want to run the motor before I put it in the boat, simply because it is a whole easier to work on it in the garage than in the engine bay! I do not have a spare wiring harness to plug in to the engine, so I need to know which of the 10 wires I need to hook up to run it where it is now.
Any guidance you can give me will be appreciated! I have the engine "turning over" and am ready to check for spark etc.
Thanks.
Lawyer at Large
stonyloam
Re: Project Boat- engine question
Are you turning it over with an ignition switch that has a start and run position? If so it should be pretty easy. Do you have the wiring harness hooked up to the engine?
Bt Doctur
None, install battery cable as you normally would,make a 16Ga jumper to go from the + side of the coil to the battery, take a second wire from the + battery and touch the yel/red on the slave or main sonenoid.
Thanks for the information. I do not have a wiring harness to use so I will be using Bt Doctur's instructions. The other question I have is: If I take the intake and 4 barrel carburetor off the locked up 488 and put it on the 470, will that give the 470 the same power as a 488, or are there other differences in the two engines such as the cam shaft, head etc.?
TheHunter990
you will need power and ground to the starter, the big cables.
You will need a regular peice of wire to provide 12v to the coil (an on off switch would be handy to turn off engine when your test is complete). another chunk of wire to jump the starter solinode (to crank the engine), and I think thats all u need.
O, and you need 12v to electric choke, it u have one.
