JohnFla321k
- May 19, 2003
- 2
My friend gave me a 1979 boat that's been sitting in his yard for at least 3 years. 20 ft proline cuddy with suzuki 140. The front hatch on cabin is gone. Rainwater sat pooled in cabin and rotted all the wood. It doesn't look like the water was able to run through to rear of boat. I found a broke bilge pump through access in floor of cabin. I cut away as much of the rotted wood as I could. Can I just cut, grind to good materials and replace wood/glass over? The deck feels solid...i can see under deck on sides of gas tank from cabin area. It looks fairly clean...i reached in and hit it with hammer and screwdriver, feels solid...is proline like this worth the repair work in your opinion? I haven't even messed with the engine yet. I used a pulley to pull it off of the transom because I thought I'd have to try to take inner liner off to get to under deck...it's looking more and more though like deck is good.
