Hello, I have an '86 Chaparral 20' "198 c xl" deep vee cuddy. Boat weighs around (best guess) around 4k. Powered by a 5.7L, 350ci chev. with a q-jet. which is mated to a gen 1 alpha 1, turning 1.84:1 gears. I have tried an alum. 3 blade 21p (4 adults with gear and 35 us gal of fuel) and have excellent hole shot and torque, with about a 5300 rpm max at gps 40 mph. I installed a 3 bld 23p alum. and with 5 adults and 45 gal. of gas it takes way too long to plane out, but after everybody steps forward on boat it finally breaks over and will hit a gps speed in excess of 50mph at 4900 rpm (ran out of room, too many other boats nearby). Both current props are in need of some repair. For me to get either prop repaired Im looking at around $80. I'm wondering what you all thought about me installing a new 4 blade alum 23p such as ( http://boatpropellers.iboats.com/Me...r=1986&**********=773233239&*******=650954847 )? The boat does get beached and would rather leave the prop alum for sacrificial sake. The usage of the boat is 60% water toys with maybe a 40% "just cruise around" split. Would this be a decent compromise between the two? What am I going to sacrifice? I'm just thinking if I'm going to spend $80 plus, might as well spend $100 (elsewhere) and get something that's inbetween the two... what are my consequences going to be???
Thanks for all of your help and thoughts.
Regards, -MV
Regards, -MV
