Hello! Fairly new pontoon owner here, trying to dial in my prop.
I'll give as much info as possible, and hopefully you gurus out there can point me in the right direction.
The issue I'm having is I am significantly under the suggested top RPM range at WOT.
Specs:
Boat: 2007 22' Sun Tracker Regency
Motor: 1998 Mercury Offshore 150 25" shaft (carbureted) http://boatspecs.iboats.com/Mercury_...8/bpe/57e16405
Prop: Solas Amita 3, Aluminum, 3-blade, D: 14.8, P: 17
WOT: Approx 4500 (speed unknown)
Gear Ratio: Unknown
The above WOT was recorded in calm salt water with approximately 600 pounds of people on board.
We plan on doing mostly lake boating though, and are going for efficient cruising above all else, but it would be nice to get some speed (mid to high 20s) and tow tubes. We will usually have a medium load on the boat (5-8 people).
From the specs I read, the RPM range should be 5000-5600, so I'd say we're aiming for approximately 5400 at WOT. Sound right?
As for the motor, we are confident it is in solid mechanical condition. We have performed compression tests (all normal) and just did a sync&link. It is a 25" shaft motor, which puts the prop a little deep in the water, but I hear that is a good thing. We are assuming the tach is correct, I have to admit, but have no reason to believe it is not (but of course anything is possible).
The boat is in excellent condition and the toons are not holding water.
So...
Is this enough information for any of you to point me in the right direction for the next prop we try?
I'm assuming we need to pitch down. What about diameter? And should I go for a 'work boat' or 'pontoon' specific prop?
Many thanks in advance for your help with this.
Attached is a photo of the transom/lower unit. Perhaps the prop is a little too deep in the water?
Specs:
Gear Ratio: Unknown
So...
