Prop Advice Needed
NCOffSeason
A friend of mine has a 17 or 18 foot Bayliner capri with the 4 cylinder engine. It's a mid to upper nineties version. The prop that was on the boat was not correct and we can't tell what pitch it was.<br /><br />For those with this boat (or close), what pitch do you run? He is looking for pulling power (ski, tubes, etc) over top end.<br /><br />Thanks,
Chris1956
Re: Prop Advice Needed
Chris, I have a 19' SeaRay Bowrider with a 4.3LX V-6 (205HP) Alpha 1 drive. I use a 21" pitch Rapture propeller. If you have an Alpha 1 outdrive, I would borrow a 15" pitch prop from the prop shop to try it. Adjust up-down in pitch from there until the boat will just reach max RPM with a normal load aboard.
KaGee
If you go HERE <br /><br />I found the cross reference to be quite helpful. You can scan the sight and find a form to fill out to get their advise on which prop to consider.
walleyehed
Post a P/N of either prop. Go run it, get a base-line and we can tell ya which way to go. It's the ONLY way to get the correct prop.
mercrewser
Looks like he needs the set up pictured in your post for some pullin power! :) . Brother inlaw has an Xstar with 330 hp. That thing pulls
NCOffSeason
Yea, he loves our boat. My Malibu has the Hammerhead engine with 365HP. Talk about pulling!
4poco
with my 2005 bayliner 175 runabout 3.0liter(4cyl)<br />there is a 19" prop.
